Shifting problems
mxo41
I have a 96 cherokee with 4.0L, AW4 transmission and 102,000 miles. After driving on the highway for an hour going 70 mph the engine seems to jump for 2200 rpm to 2600 or even 3000 rpm. There is a loss of power at these high rpm. I have checked transmission fluid and it looks fine. Gas mileage is also low around 13-15 mpg. Another problem maybe related or not is the four wheel drive light does not go on. Checked fuses and all look fine. Any ideas on where to look.
Have you had the transmission serviced? Fluid and filter? It may help if it needs it.
Otherwise I'd suggest taking it somewhere they can hook it up to diagnostics and find out exactly what isn't working in the transmission. Shouldn't be hard since the AW4 has it's own computer.
Hi,
Sounds like maybe the Torque converter is slipping/releasing when it shouldn't be? I agree with Bounty, see if you can find a way to check the transmisison's computer system. You should be able to do this through the Powertrain Control Module (PCM aka main computer) using an OBD-II style scanner. :mrgreen:
-Nick :!:
I hooked up the jeep to an OBD-II scanner but it passed. I am not sure but i thought OBD-II scanners only worked when the check engine light comes on. Since mine was not on I think it passed. I was wondering if maybe the Throttle Position Sensor could cause this problem of shifting. I heard that even if it is bad it can give a voltage in the expected range so the check engine light will not come on.
Hi,
You need to use the scanner to read any transmission codes that may exsisit. OBD-II does throw many codes that do NOT light the check engine lamp.
Also, a throttle position sensr could cause erratic shifting, but would most likely cause the engine to run poorly or sparaticly as well :mrgreen:
-Nick :!:
Well i went to the dealer and had them test everything. They said that all three solenoids (my guess would be just the 3rd-overdrive one but i think they wanted extra money) in the transmission for shifting were bad. Does someone know how to change these and where i can buy them? Any help would be great. Dealers overpriced estimated was $1322.
