X XRedLegX New member Jan 7, 2012 #1 Have a 2000 wrangler 2.5L. Would taking off the boulder guard underneath save me any MPG?
5 56cj5 New member Jan 8, 2012 #2 Are you talking about the main skid plate?? If so you cant remove it ... It's your transmission mount.
J Jeepergeo Active member Jan 8, 2012 #3 You'd need to shed a lot of weight to make much difference in your MPG. I would not do it. How you drive and how well you maintain the air pressure in your tires are more likely to have an impact on MPG.
8 82cj7son New member Jan 8, 2012 #5 are they aftermarket tire size or stock tire size? if stock check your manual for appropriate tire pressure
