I've used it, works great. Use a vacuum source, I used the brake booster vacuum, but only use the recommended amount. It shouldn't die while doing this, but you turn the engine off immediately when done and let it sit 15 minutes before restarting. Supposed to clean valves and the catalytic converter.
You can add it to your engine oil and fuel as well.
