Rugged Ridge 07-11 JK Wrangler 2" Trailer Hitch and Wiring Harness Kit
Baseline 4x4
Custom Design bolts directly to factory mounting locations for easy bolt on installation. Wiring harness plugs directly into existing wiring. Designed as a one-piece welded assembly for added strength, This Rugged Ridge built this Hitch Receiver to match the towing capacity of your Jeep: 3,500-lb tow rating, 350-lb tongue weight rating with weight distributing equipment; otherwise 2000-lb tow rating, 200-lb tongue weight rating, 2" opening.
11580.10 - Rugged Ridge Rear 2" Hitch, 07-11 Jeep JK Wrangler
17275.01 - Rugged Ridge TOW HITCH WIRING HARNESS, JEEP WRANGLER JK 07-11
Or buy these as a kit and save money
11580.51 - RUGGED RIDGE HITCH KIT, JEEP WRANGLER (JK) 07-11, INCLUDES HITCH AND WIRING HARNESS. HITCH RATED AT 3500LBS FOR 4DR AND 2000LBS FOR 2DR BLK
Great and easy way to put a hitch on your Jeep. No modifications needed to install.
