Rough Country 4 inch lift!!
jleland
Rough Country 4 inch lift!! SOMEBODY HELP!! PLEASE
Got started last night installing this lift on my YJ......by myself with hand tools!!! Yes it sucks!! All my help bailed on me
I want to know if there is any easy way to remove the sway bar end links? I got 1 of them off after about 45 minutes! Also, I'm not quite understanding the whole brake line relocation. To me, it seems like it would be better to run the line around the outside of the shock on the front. The instructions aren't real clear on this.
Well I guess the wife and I are gonna give it a go today and try our best to finish this thing
Not enough hard line to go in front of the shock. Just unbolt the brake line from the side of the frame and move it further down. As for the swaybar, I don't run one any more, so if it were me I'd start cutting.
been in that same situation so many times finally went out got me a comp with air tools now its all easy sailing
The sway bar link came off with the pitman arm puller! I wish I woulda thought of that last night. I ran the driver's side brakeline behind the shock boot inside the upper shock mount and drilled a new mounting hole on the front side of the shock mount. Hopefully this doesn't compromise the integrity of the upper shock mount. Next we are taking the sway and track bars off and leaving them off! The wifey is gettin kinda nervous but I let her read acouple threads and articles about removing these bars. Wish me luck, I have to finish today so I can get to work tomorrow.
