Rocker switch install??
cheech66
Anyone install these Daystar switch panel/rocker switch. No directions and website no help. I will probably just take a swing at it just curious if anyone has installed these, I also want to hook the switches up through the fuse block under the hood have not done that either so any info with that would be helpful tks!!!:???:
Are these the switches that fit into the sockets in TJ's near the ash tray?
If it is you just need to take out the center plastic piece and pop out the blank caps.Then push the the rocker in place.
