redrooster
There is an interesting event taking place tomorrow at Morris Mtn ORV. The Southern Buggies have challenged all comers to a timed race up Los Primos at Morris Mtn. Ironically enough it is the trail in my avatar.
The trail is about a 1/4 mile long ravine between two ridges. The finish line at the top is where the two ridges come together. The last section of the trail has two 4' steps with a deep hole between. I have 24" of belly clearance and when my front tires (42's) drop in the hole, the belly pan sits on the rock. To make it clean you basically have to wheelie up the first ledge over the hole. Even more interesting is that when you break traction, the hill tries to slide you left and then over on your lid if you're not quick on the brakes. (You Moab flunkies don't know anything about the wet southern trails.)
I think the dune buggies are going to smoke the 4x4's on the bottom section as it is just a drag race up to the stair steps. It should get interesting from there. Evidently the buggy guys think they can make the steps because they chose the trail. It's going to be fun to watch.
