I need to replace the original radiator in my 1985 Cherokee. Do I need to purge the AC system and remove the condensor with the radiator or can the radiator be removed without removing the condensor.
you should be able to just replace the radiator without messing with the ac hoses/condensor etc.. if your ac was working before the Rad failure you should just replace the Rad and purge your Rad hoses.
