Raunchy Rancho Rockcrawler Lift
Natty
Howdy, anyone know anything about the 2.5" Rancho Rockcrawler lift for TJ's? Compared to Old man by the sea Emu systems? Have curious friends. Inquiring minds want to know. Thanks, Matt.[addsig]
1043923
<TABLE BORDER=0 ALIGN=CENTER WIDTH=85%><TR><TD><font class="pn-sub">Quote:</font><HR></TD></TR><TR><TD><FONT class="pn-sub"><BLOCKQUOTE>Howdy, anyone know anything about the 2.5" Rancho Rockcrawler lift for TJ's? Compared to Old man by the sea Emu systems? Have curious friends. Inquiring minds want to know. Thanks, Matt.</BLOCKQUOTE></FONT></TD></TR><TR><TD><HR></TD></TR></TABLE>
What do you want to know about it?
OME is just springs, shocks, bumpstops and a rear trackbar relocation bracket. But it yields a much softer ride. technically it's not a lift, it's a "suspension uprgrade" but you can see anywhere from 1-3" of lift from it depending on the springs you chose (soft, medium or heavy) and the weight of the vehicle. 32x11.50 tires are the largest I'd recommend trying to fit with this lift alone.
The Rancho has the same parts as the OME but adds front and rear LCAs, a drop pitman arm (probably not needed), front quick discos, front extended brake lines and a front adjustable track bar. It will yeild you between 2.5-3.5" and will allow for fitment of 33x12.50s but is quite a bit more expensive as well.
HTH
