Radiator Drop Brackets On PA Body Lift
Hey folks,
Just getting ready to finnaly install my 1" PA body lift.
From what I understand, the Radiator Drop Brackets included with the kit are designed to actually lower the entire radiator. However, I believe I read somewhere you can just unbolt the shroud itself and install the same brackets to those stock holes and just lower the shroud, and not actually have to lower the entire radiator. Is this what most people do?
Am I making any sense at all?
-Rob
it would probably be easier yo go get your self an electric fan from a taurus and wire that up so u get rid of the clutch fan. with out that clutch fan you will gain a few more horses and less engine drag..
What are you, Dixie or Yankee?
Yes but It won't really matter with only 1" lift. the motor and radiator will still be lined up pretty close to each other. if it was something more drastic like a 3" BL then I would recomend dropping the radiator. most of the air that is pulled off the radiator wil still pass over the mtor.
