I topped off the fluid level in my gear reduction unit today & found it took approx. 2.5 quarts to fill it which is what the manual says it holds. I then proceeded to remove the fill plug on the Quadra-trac only to have fluid come rushing out.
I'm assuming the seal between the reduction unit & transfer case is toast and permitted the fluid to flow into the transfer case causing an over full level.
If this is the case (I know I should fix it but until then) is it tollerable for the quadra trac to be over filled or is it better to let the reduction unit run low?
I have a date at the dunes with some other 4x4s coming up real soon & my not have time to replace this seal.
