Allen's Offroad
07-10 Jeep JK Trail & Street Cylinder Assist Kit SK-255
Click image to enlarge!
PM for pricing to your door! All other PSC products are also available!
Have you installed 35" or larger tires on your JK and are now suffering from steering woes? Well if so, AOR now offers PSC Motorsports complete cylinder assist steering kits for '07 and newer JK series Jeeps. Kits consist of all new steering components pictured, including a 100% new steering gear and pump. All steering cylinder mount brackets bolt straight onto the stock axle housings and tie rods with the use of a few hand tools. In fact, the only special tools required for installation are a pitman arm puller and a 1-5/16" socket for the removal and replacement of the pitman arm.
This kit is designed for trail & street applications. For extreme duty applications, PSC Motorsports offers the SK-260. Please note that the brackets in this kit will only work with the stock JK axles.
Kit Includes:
SG675R - Jeep JK Cylinder Assist Steering Gear
SC2221 - 1.5" Bore x 6.75" Stroke x .625" Rod SE Steering Cylinder
MB35 - JK Cylinder Mount Bracket Assembly w/Rod Ends
HK2035 - JK Cylinder Assist Hose Kit
PK1653 - JK Cylinder Assist Kit for 1.5" Cylinder
Thank you very much! I am grateful for your business.
Allen
