pros and cons of headers vs. manifold ?
1981CJ5
trying to decide if I should install headers on my '81 CJ5. Can you give me some pros and cons of the headers vs. the manifold?
headers are louder, tend to blow gaskets, and expensive. but you can see performance gains if the rest of the system is up to par
if you are adding headers, add the intake too and even a cam down the road to fully reap the rewards.
-Both units must be removed to replace one, and since they share the same gasket, (the NEW header and the STOCK intake) one will blow the gasket -probably the exhaust.
check out http://cliffordperformance.com/home.htm
adding the header alone will mke the motor a lil more efficient but you probably wont notice anything except the exhaust leak
