problems replacing lower steering bearing
they should snap together if I remember correctly. It was a tight fit but they go together.
If it slipped out should slip back in. I'm not familiar with the bearing your talking about but this may help if it's a small clearance issue. Put the bearing in the freezer for a couple hours or so, this will shrink it. Then at least have the race in a warm place, like out in the sun for a while. You'd be suprised how much expansion an contraction you'll get. If it don't work we go to plan B.
Hey Jeepn4Fun,
I wrote that tech blog your referring too. We are talking about the white plastic bearing fitting into the black metal race correct? As the other guys pointed out, it is a tight fit and they will only fit in one way. They should snap together. I like Flatie's idea as it is a tight fit.
