dingus
Active member
1042566
last night i drove around for a good half hour, then stopped. jeep was fine. drove home. jeep was fine. this morning i drove it around for seriously like 3 or 4 minutes, the temp guage was skyrocketed and i pulled over. luckily i don't trust this thing yet and it drank a GALLON of coolant. then this afternoon after my SAT's i drove it home and drained out all the coolant. right out of the radiator... by popping the grill off and opening up the bleed valve on the radiator. then i filled up the overflow tank but it didn't take, so i started it up and after a few minutes it overheated, and didn't suck any of the coolant down. so i opened up the bleed valve and then it SLOWLY accepted the coolant. so then we filled it up, added some stop-leak, and went for a drive. we let it sit idling in my driveway for a good 20 minutes while we cleaned up my garage and moved some cars around. it was perfectly at the dead-middle range (NOTE: heat was on full blast)... then we drove through town, having some fun etc... parked. jeep was fine. (Note: now, the heat is off) 20 minutes later, we get back in and drive through town and about 10 minutes later i check on the temp gauge and its in the beginning of the red zone. we drove home and popped the hood and it leaked out a LOT of coolant all over my driveway. luckily its raining right now, its being washed away. when it leaks it comes out the overflow tank both at the bottom hose (which has the little cheezy clamp on it) and out the lid (which was screwed on pretty tight).
and now between posting this and editing it, i went out and checked it out again. i started it up and let it reach operating temperature. then i let it keep sitting and it overheated to 3/4 temperature (on the guage)... then i hit the gas and held it at about 2500-3k rpm's and the temp dropped back down to normal. heat had no affect on this. i tried it with and without heat on...
any insight here? i'm just a poor highschool kid and don't really wanna just send it into a shop...
