Overhead Trip mini computer w/Temp & Compass no input H
dlbedford
Recently I had the a/c cool air radiator that lives under the dashboard changed out as it was leaking. This is the second one they've put in in 120,000 miles. Terrible design. But my problem is that since that installation, having to take the dashboard loose to do it, I now have ZERO input to the engine gas mileage readings, and have no temperature reading just two dashes. I assume that something has been pulled loose. Can anyone tell me where to look for this connection? Where does the temperature sensor live on the Jeep ? My son has a Durango, and his temperature on his overhead console is showing OC.
Any information would be appreciated.dl_bedford@netzero.com
1046633
Did you perform the install? If so, just try to re-trace your steps and see if you stumble across and loose or out-of-place connectors. Get a shop manual and see where the input for the gauges originates. Dont forget to check all the fuses and other simple stuff first. Keep us posted.
Good luck!!
Robbie
