Ordered my lift
BostonJeep
Well its official. I ordered my lift kit, bumper, and decided on tires.
3.5" BDS lift with shocks, springs, pitman arm, discos
32" BFG AT KO's
should be here on monday IM SO EXCITED.
just thought id share -
Cool. Glad to hear the news. Be sure to post some pics of the finished product. Can not wait to finially do a lift to my rig one of these days.........
:D Suh-weeeet! That is exactly the same setup I have. The only things I want to change suspension wise is maybe a 1 inch taller than stock (1/2" lift) shackle (angled in rear) to get a little better clearance on those big military wrapped spring eyes, and discos (I just unbolt them for now)
We surely will want 2 see pix.
One thing BDS doesn't recommend in their paperwork/instructions that they DO recommend on their website is to loosen the two bolts under the transfer case when you're done, ride around the block relatively gently, and then tighten them back up. This allows the transfer case to adjust itself to the new driveline angle and Xfer case drop. FYI - I have absolutely ZERO driveline vibration
