Vanmantraveler
OK I am on the fence here.... I am more then willing to listen to all Edgimikated, Pea brained, and wild ass guesses from all comers....
I have a 81 CJ5 that I picked up out of a field for free... Not that there is much left of the body after sitting there since the early 90's. But anyway that will be fixed in due time. Stock it came with the old reliable but way under powered 2.5L GM cast iron duke and a 4 speed Weakbox, stacked infront of the ever popular Dana 300. (I can already see the twin stick sticking out of the floor in my mind!!!!!)
So now after flapping my fingers around for 5 minutes, time for the question.... I know I will be sorry for this.....: What Motor/Transmission combo should I stack into the frame rails?
The way I was thinking I have three ways to go... ALL by the way 5 Speeds... These are not in any order by the way.
First choice 4.0 L H.O.
Second 5.7L chevy Throttle port Injection (hummm where to put the puter so it will not get wet forging the water traps at the local golf course?)
Third 4.3L Throttle port injection (Throttle port... easy to Snorkle...)
I know I know... the stock CJ tooth pick axles will not hold up but that too will change. looking for a front 44 to go with the 44 rear I just picked up... Grand Cherokee unit... can you say wider axle?.
Thanks for the Input PPLS...
Troy
Troy
