MrChubbyHubby
Since I bought this thing, the Oil Pressure Gauge has not worked right. When I start the Jeep up, it takes about 3 seconds for the gauge to peg to the right above 80. The needle never moves until I shut it down.
Here are my questions:
Is the OP Sensor located on the left side of the motor right behind the alternator?
If so... is this a good place to start troubleshooting / replacing?
IF that is the OP sensor, I disconnected the harness to it and started the jeep up last night, and I got the same result as if it was connected.
hmmmmm????????????
Could something be connected wrong under the dash????
Any thoughts would be greatly appreciated. Thanks
hmmmmm????????????
