Sounds like your problem may be elsewhere, like too much crankcase pressure and/or blowby. Too much crankcase pressure will blow oil out the path of least resistance, like the oil fill cap, valve cover gasket, rear main, dipstick, etc. Make sure the PCV system is working correctly, and maybe consider a compression and leakdown test.
