I bought an 85 CJ7 with the 4.0L that had been sitting for 6 years. Engine was not seized. The engine had good oil pressure and lifters were not noisy. After changing the oil the lifters are now noisy and the noise does not stay in the same area of the engine. I have used 5w30, 10w30 in an attempt to find a solution. I have also inspected and replaced the main and rod bearings and also has a new oil pump. With a mechanical gauge, I have 60-70 psi of oil pressure cold at idle and once at operating temp, oil pressure is roughly 10 paid at idle. Any thoughts?
