GenRight Off Road
- Ultra Hi ground clearance shape provides your Jeep best approach angle.
- Winch is recessed down between frame rails for better air flow to the radiator.
- Extremely light aluminum construction..
- Greatest protection for your winch on the market.
- Can be painted or powder coated or left in natural aluminum finish.
- Will not rust or corrode.
- Best balance between strength and weight!
- Laser Cut and formed from 3/16" thick 6061 Aluminum Alloy.
- Unsurpassed quality and hand TIG Welded.
- This model features a 1-3/4" thick wall tube protects the winch.
- Our uniquely designed winch tray will fit Warn; Power Plant, Zeon & CTI winches.
- Fits the 2 door and 4 door Jeep JK.
- Compact design fits tight to the frame and wraps around each side.
- 8 bolt mounting fits tight up against the frame.
- 100% Made in USA!
Use code GRCHRISH on our website to save 10%! GenRight JK Low Profile Winch Guard Front Bumper - Aluminum
Also available without the winch bar:
