Allen's Offroad
Lot's of new package deals for you guys. Same warranty, same quality, same everything. Free Shipping as always for these. California residents add 7.5% sales tax.
For a limited time only, mention JEEPZ.COM and get 10% off pricing below.
Rev-JK-Non-456 JK Non Rubicon (D44/D30) 4.56 gear package front & rear with master overhaul kits (Front case required for factory 3.21 ratio only) $604.80
Rev-JK-Non-488 JK Non Rubicon (D44/D30) 4.88 gear package front & rear with master overhaul kits (Front case required for factory 3.21 ratio only) $604.80
Rev-JK-Non-513 JK Non Rubicon (D44/D30) 5.13 gear package front & rear with master overhaul kits (Front case required for factory 3.21 ratio only) $604.80
Rev-JK-Rub-411 JK Rubicon (D44/D44) 4.11 gear package front & rear with master overhaul kits $660.15
Rev-JK-Rub-456 JK Rubicon (D44/D44) 4.56 gear package front & rear with master overhaul kits $660.15
Rev-JK-Rub-488 JK Rubicon (D44/D44) 4.88 gear package front & rear with master overhaul kits $660.15
Rev-JK-Rub-513 JK Rubicon (D44/D44) 5.13 gear package front & rear with master overhaul kits $660.15
Rev-JK-Rub-538 JK Rubicon (D44/D44) 5.38 gear package front & rear with master overhaul kits $660.15
Rev-TJ-D35-373 Jeep TJ & 96-04 Grand Cherokee (D35/D30) 3.73 gear package front & rear with master overhaul kits (Does not include carrier cases) $506.25
Rev-TJ-D35-410 Jeep TJ & 96-04 Grand Cherokee (D35/D30) 4.10 gear package front & rear with master overhaul kits (Does not include carrier cases) $506.25
Rev-TJ-D35-456 Jeep TJ & 96-04 Grand Cherokee (D35/D30) 4.56 gear package front & rear with master overhaul kits (Does not include carrier cases) $506.25
Rev-TJ-D35-488 Jeep TJ & 96-04 Grand Cherokee (D35/D30) 4.88 gear package front & rear with master overhaul kits (Does not include carrier cases) $506.25
Rev-TJ-D35-513 Jeep TJ & 96-04 Grand Cherokee (D35/D30) 5.13 gear package front & rear with master overhaul kits (Does not include carrier cases) $506.25
Rev-TJ-D44-373 Jeep TJ (D44/D30) 3.73 gear package front & rear with master overhaul kits (Does not include carrier cases) $519.75
Rev-TJ-D44-410 Jeep TJ (D44/D30) 4.10 gear package front & rear with master overhaul kits (Does not include carrier cases) $519.75
Rev-TJ-D44-456 Jeep TJ (D44/D30) 4.56 gear package front & rear with master overhaul kits (Does not include carrier cases) $519.75
Rev-TJ-D44-488 Jeep TJ (D44/D30) 4.88 gear package front & rear with master overhaul kits (Does not include carrier cases) $519.75
Rev-TJ-D44-513 Jeep TJ (D44/D30) 5.13 gear package front & rear with master overhaul kits (Does not include carrier cases) $519.75
Rev-TJ-Rub-456 Jeep TJ Rubicon 4.56 gear package front & rear with master overhaul kits (Comes with thick gears so no carriers needed) $573.75
Rev-TJ-Rub-488 Jeep TJ Rubicon 4.88 gear package front & rear with master overhaul kits (Comes with thick gears so no carriers needed) $573.75
Rev-TJ-Rub-513 Jeep TJ Rubicon 5.13 gear package front & rear with master overhaul kits (Comes with thick gears so no carriers needed) $573.75
Rev-TJ-Rub-538 Jeep TJ Rubicon 5.38 gear package front & rear with master overhaul kits (Comes with thick gears so no carriers needed) $573.75
Rev-YJ/XJ-D35-410 Jeep YJ/XJ 84-96 (D35/D30 reverse) 4.10 gear package front & rear with master overhaul kits (Does not include carrier cases) $492.75
Rev-YJ/XJ-D35-456 Jeep YJ/XJ 84-96 (D35/D30 reverse) 4.56 gear package front & rear with master overhaul kits (Does not include carrier cases) $492.75
Rev-YJ/XJ-D35-488 Jeep YJ/XJ 84-96 (D35/D30 reverse) 4.88 gear package front & rear with master overhaul kits (Does not include carrier cases) $492.75
Rev-YJ/XJ-D35-513 Jeep YJ/XJ 84-96 (D35/D30 reverse) 5.13 gear package front & rear with master overhaul kits (Does not include carrier cases) $492.75
Rev-YJ/XJ-D44-410 Jeep YJ/XJ 87-96 (D44/D30 reverse) 4.10 gear package front & rear with master overhaul kits (Does not include carrier cases) $506.25
Rev-YJ/XJ-D44-456 Jeep YJ/XJ 87-96 (D44/D30 reverse) 4.56 gear package front & rear with master overhaul kits (Does not include carrier cases) $506.25
Rev-YJ/XJ-D44-488 Jeep YJ/XJ 87-96 (D44/D30 reverse) 4.88 gear package front & rear with master overhaul kits (Does not include carrier cases) $506.25
Rev-YJ/XJ-D44-513 Jeep YJ/XJ 87-96 (D44/D30 reverse) 5.13 gear package front & rear with master overhaul kits (Does not include carrier cases) $506.25
Rev-XJ-8.25-410 Jeep XJ 91-99 (8.25/D30reverse) 4.10 gear package front & rear with master overhaul kits (Does not include carrier case) $538.65
Rev-XJ-8.25-456 Jeep XJ 91-99 (8.25/D30reverse) 4.56 gear package front & rear with master overhaul kits (Does not include carrier case) $538.65
Rev-XJ-8.25-488 Jeep XJ 91-99 (8.25/D30reverse) 4.88 gear package front & rear with master overhaul kits (Does not include carrier case) $538.65
Rev-XJ-8.25-513 Jeep XJ 91-99 (8.25/D30reverse) 5.13 gear package front & rear with master overhaul kits (Does not include carrier case) $538.65
Rev-XJ-8.25/D30S-373 Jeep XJ 96-01 (8.25/D30 short) 3.73 gear package front & rear with master overhaul kits (Does not include carrier case) $538.65
Rev-XJ-8.25/D30S-410 Jeep XJ 96-01 (8.25/D30 short) 4.11 gear package front & rear with master overhaul kits (Does not include carrier case) $538.65
Rev-XJ-8.25/D30S-456 Jeep XJ 96-01 (8.25/D30 short) 4.56 gear package front & rear with master overhaul kits (Does not include carrier case) $538.65
Rev-XJ-8.25/D30S-488 Jeep XJ 96-01 (8.25/D30 short) 4.88 gear package front & rear with master overhaul kits (Does not include carrier case) $538.65
Rev-XJ-8.25/D30S-513 Jeep XJ 96-01 (8.25/D30 short) 5.13 gear package front & rear with master overhaul kits (Does not include carrier case) $538.65
Rev-XJ-D35/D30S-373 Jeep XJ 96-01 (D35/D30 short) 3.73 gear package front & rear with master overhaul kits (Does not include carrier case) $498.15
Rev-XJ-D35/D30S-410 Jeep XJ 96-01 (D35/D30 short) 4.10 gear package front & rear with master overhaul kits (Does not include carrier case) $498.15
Rev-XJ-D35/D30S-456 Jeep XJ 96-01 (D35/D30 short) 4.56 gear package front & rear with master overhaul kits (Does not include carrier case) $498.15
Rev-XJ-D35/D30S-488 Jeep XJ 96-01 (D35/D30 short) 4.88 gear package front & rear with master overhaul kits (Does not include carrier case) $498.15
Rev-XJ-D35/D30S-513 Jeep XJ 96-01 (D35/D30 short) 5.13 gear package front & rear with master overhaul kits (Does not include carrier case) $498.15
Rev-ZJ/WJ-410 Jeep Grand Cherokee 96-04 (D44HD/D30short) 4.10 Gear Package Front & Rear Gears & Master Kits (no front carrier) $681.75
Rev-ZJ/WJ-456 Jeep Grand Cherokee 96-04 (D44HD/D30short) 4.56 Gear Package Front & Rear Gears & Master Kits (no front carrier) $681.75
Rev-ZJ/WJ-488 Jeep Grand Cherokee 96-04 (D44HD/D30short) 4.88 Gear Package Front & Rear Gears & Master Kits (no front carrier) $681.75
Rev-ZJ/WJ-513 Jeep Grand Cherokee 96-04 (D44HD/D30short) 5.13 Gear Package Front & Rear Gears & Master Kits (no front carrier) $681.75
Let me know if you want/need a carrier or locker. Now online at Allen's Offroad. Use coupon code "REVPKG10" at checkout for the additional savings.
Have a blessed and prosperous day!
Allen
Allen
