need new carb any suggestions
jeep90
I have a 1990 yj in need of a new carb. It hesitates and cold starts are awful. I was thinking weber because I hear it is a good replacement. New to carbs not sure if mine is 1bbl or 2bbl. If anyone with the weber wants to share their experience i would appreciate it. also how do I tell 1bbl or 2 bbl. thanks[addsig]
1067980
well, for starters, what kind of engine do you have in your yJ?
typically the 4 cyl's are 1bbl and the 6 cyl's are usually 2bbl
Best bet if you are not sure, take off the air filter and LOOK at how many barrels are in the carb :-D
Then again, if it turns out you happen to have a throttle body fuel injector, then disregard everything i just said... :roll: [addsig]
1067984
Go with the Weber. I put a Weber on a couple of months ago and it hasn't stalled Yet.[addsig]
1067987
i have a 6 cyl. when i remove the air cleaner i only has 1 barrell.[addsig]
1067988
it only has one opening ito the manifold anyway. like i said im new to this carb stuff. also where is the best place to get a weber kit?[addsig]
