Need fuel pump replacement step by step!
bonzLamar
Can't afford to take to the "stealership" :twisted: so I really need to replace it myself... :redface: any instruction help muchly appreciated.:cry:
Thanks in advance!
JeepOn!
Oopz... it's a '92 cherokee 4.0
If I remember right, it's pretty easy on yours. If you get under the Jeep you can see the fuel pump on the upper front of the tank. Remove hoses and wires, turn the ring holding the pump in the tank (may take some persuading), and pull the pump out. Reverse procedure to install new pump.
I think in 97 newer you need to drop the gas tank.
Make sure to have the tank drained so you can achieve maximum fumes and always have a lit cigarette handy:purple: :purple: :purple:
Just Kidding!!
How much fuel is in the tank now?
