1041374
After gearing up to change the fluids in the Trans., and Transfer case in my
99TJ, I noticed that they aren`t clearly visible. (what is that one plug that
has a wire lead through it?). Anyway, do you have to remove the skid plate
-trans. mount to access the drain and fill plugs? If so, where is the best place
to place a jack to hold the trans. and tranfer case up while the mount is
removed?
Thanks for any and all replies!! [addsig]
removed?
