1057170
oil pressure is usually somewhere between 20 and 60... depending on how cold the engine is, and how much oil you have in there, and if the oil pump is working, and if there are bad leaks anywhere. the oil pressure sensor is located below the oil filter, and has 2 wires on it. very easy to replace, costs 40 bucks at napa, and about 5 minutes to replace.[addsig]
