Looking for a Weber carb
DanYJ
Hey, I'm looking for a weber carb for my YJ. I'm looking to replace the stock carter carb. Anyone that could help me out will be greatly appreciated. Thanks
Go with the Motorcraft 2150 rather than the Webber and in the end you will be glad you did. Less Money and ezer to set up to run right! tug
The Motorcraft runs a lot better than the weber at extreme angles, from what I've seen. You'd think it was FI :shock:
You'll need a Mr. Gasket adapter plate for the Motorcraft, I think Tug should have the part #.
Look on ebay. They have the best prices on these. My weber has never given me a single problem. Know I cant speak for the previous owner he was told some bs that it washed out his cylinders and caused his engine to go. I took that same weber got a rebuild done and a lifetime warranty for under 200 bucks. Have had zero problems in over a year. He has had no problems with his new weber either. The one I got from him was a hand me down from a tfi upgrade of a unkown person.
after owning both I would highly recommend the motorcraft. I hated my weber, and all it did was kill mileage, rob my power, etc. yes it was setup correctly.
:edit: motocraft is alot cheaper too!
MOtorcraft 2100 and 2150 is as common as dirt. Ford put em on every thing from the Pinto to the trucks. Good piece of equipment. I had ol Tugly up on the driver side wheels and going up a 10% grade and the motor never died or sputtered a time. I am a beliver! tug
what does the Mr. Gasket #1935 adapt?what to what? I couldnt find that exact part # on there web site. I want to do the 2100 conversion to mine as well and was planning on making the plate, but if its available that would be much better.
thanks
