This is the case and was wondering if anyone knew for sure if longer aftermarket control arms would stop the problem. It is not the track bar. Had a Fulltraction adjustable with the tie rod like end, but switched to a Rubicon Express adjustable. No movement there and everything is centered. Alignment has been done 3 times and is good. 33" BFG's are properly inflated and balanced.
Tell me the control arms are too short and it is pointing the front axle slightly down which is the root of the problem.
