I have FINALLY found THE tool needed for the Transmission Drain and fill plugs. I don't know If I have mentioned it before but I will make sure I do now.
Go to Sears and look in the HEX-Key (Alen-wrench) section Find the LARGEST you can spot. It should be a 17mm Hex-Key, It is a perfect fit for the newer Crysler Transmission of the newer Jeeps.
Hope it helps.
Hope it helps.
