Check the connection to the TPS. You might exercise the butterfly valve several times even take the TPS off and bast some air in. But that's only a slim chance there is dirt in there. You likely need a new TPS.. Buy oem only. Others fail right out of the box.
Regards,
JPNinPA
Sent using TapTalk
