ITS DONE!
93bizzleYJ
Its done!
3.5in BDS lift
1/2 inch lift shcakles
33x12.5 goin on soon...can't wait...so much higher...
still gotta put discos on and dropped pitman arm, everything else is done though.
-bg
93 YJ 2.5L 3.5inch BDS Lift 1/2 inch BDS lift shackles
Pictures pictures pictures! Ya we need pictures!
Disco's are a breeze. Pitman arm is another story. I actually had a shop up the street do the arm and the alignment together the same day. Next time I'm taking Snitty's route though - a cut-off wheel! I need to buy one anyhow.
I hope you put the bumpstops on if you're going with 33's!
Sweet man can't wait to see how it looks!
I told you guys I would eventually find a camera
That's awesome!! It's always exciting when you finish something that big on a vehicle!
Don't forget the pics too
my pitman arm was quite a breeze. i got a puller and tightened it up like all hell and it wouldnt come loose, so i put a 4 pound maul behind it and started whacking it like a red headed step child and it jsut popped after a few hits. lots of lube constantly for the week prior helps too.
The puller/hammer combo is the trick. Strike the pitman arm around the steering shaft at a 45* angle to the steering shaft.
Yep. You may have to do it 20 or 30 times, throw 14 different tools across the shop, and yell profanity at the person standing closest to you.....but it almost always works. :lol:
