I Need Help!!
fsjtrash
I just bought a '94 Grand Cherokee Limited. It's got power everything, but a few km's on it.
The power seats just failed, as did the rear drivers side window.
How do I fix it? Maybe it's just shorted out. Are both the front seats under the same circuit? Both failed at the same time. Is it too much to do at home, or should I just get it fixed at a shop...
Also, I'm assuming the motor for the window is gone, but some of you may think otherwise, and I encourage those thoughts to be expressed here.
Please e-mail me at breakeronenine@hotmail.com if you've got a solution.
Sounds like a blown fuse or a wiring issue. You'll just have to go to town with a multimeter and check for continuity and voltage where it should be.
Thanks, but it seems the altenator was cooked, and ended up setting off the alarm system, killing all the electrical, and killing the battery. All is fixed though, and thanks for your help.
