sweetpeet New member Mar 8, 2011 #1 I just put in a Hurculiner. I forgot to drill out everything I wanted drilled before k painted it. Will the Hurculiner crack, if so how bad?
54cj3b New member Mar 8, 2011 #2 Should be ok but when cleaning out shavings don't sweep use a shop vac sweeping gives liner a grayish look
R rdtj New member Mar 9, 2011 #3 it doesnt crack it will chip though it you dont get it thick enough. I didnt get it really thick by the gas pedal on mine and it started chipping
