98Chero
I think I have found my idle problem ? The IAC ( Idle Air Control ) is not moving, but when I turn the ignition switch to on two of the four pins that connect to the IAC light up.I have already done a complete tune-up and checked for vacum leaks and all electrical connections are good. the problem started all at once on a cold morning, before that the engine ran good Im puzzeled ?. If I could better understand how the IAC works it might help me figure out the problem.
specs
1996 cherokee sport 4x4 4.0 engine automatic trans
specs
