I need to know how the easiest way to adjust the kickdown throttle in a 4x4 89 jeep cherokee laredo. Is it something that I can do alone or need special tools for or do I need to take it to a shop? Thanks for your help
There is no kickdown cable. There is a TV (throttle Valve) cable attached to the throttle linkage at the throttle body. I believe you push and hold the button on the linkage, manually open the throttle plate completely, and release the button.
