1062004
Believe it or not, there is a big difference between the two! The K&N unit is made out of plastic and positions the air filter to the far side of the engine compartment and is a true cold air intake, (not drawing in hot engine air) that why there is that encasment around it. Because it is made of plastic, it will not absorb the heat the because plastic has less transfer.
I have a turbo city intake which is now called Rock-it, I like it, better than stock, but has it's draw backs. Made of metal, transfers heat, and places the filter just to the right of the engin where it draws in heat from the engine.
The point of these intakes is to provide cold, denser air to the engine to improve combustion, and also provides more air quicker by increasing the size ot the intake, and removing the baffles which silence the intake, but slows down the air. That why when you put on a tube, you get that whistle sound. I like the sound though, sounds like a turbo spooling up.
When I bought mine about two years ago, K&N did not make a cold air kit of a YJ. I think they do now, as soon as I get some $$ I will get one.
Hope this helps.[addsig]
