Hi flow throttle body power increase?
Mike1
Hi
The hi-flow throttle body replacements for 4.0L XJ's. What is the traditional power increse gained from this conversion and is it noticeable when in 4th gear overdrive with the auto box configeration?
Mike(SA) :D
Most people I´ve heard that have done the mod. and some of the manufactures literature, say most of the increase, is in the mid to high RPM range. 2000 RPM is a pretty good clip in high gear.
Bigger throttle body equals lower vacume at greater than say half throttle, could cause problems, especially if your vacume system has some small leaks, things add up. Lower than expected intake vacume. can give some of your sensors, a hissy fit, been there done that. Can actually cost you torque or grunt, right at the RPM range, where you need it most, low to mid.
I noticed quicker throttle response, and more power, but with a 2.5L engine. Most noticable was being able to climb hills easier and further before having to downshift.
Many people buy the bigger throttle body, instead of regearing, thinking that more power is gonna turn the big tires better. May a little, but I don´t think a lot. Might help it rev a little faster, but most of the difference is gonna be at higher RPM´s.
Heard of many who installed adjustable MAP sensors, after the throttle body change, to deal with the reduced intake vacume and to tune the throttle body function a bit.
Not to mention it's no help to the overworked transmission!
No doubt about it... gear first, throttle body second. I still am amazed at the difference gears make.
(1)Wheel Adapter 6 on 5.5" to 5 on 4.5"
Hi
Thanks for the advise.
Does anyone know where the new gearing can be purchased, and how much one should pay. I am now on stock standard 98 4.0L gearing, whatever that might be?
Mike
Picking gears, is usually done by matching tire size, to the new gear set. First thing to do is figure, what tires you are gonna be running, what differential and gear set you have.
Many of the major gear suppliers, have a chart showing, the shape of the differential cover, to identify the differential you have.
Often there is often a tag, on a differential cover bolt, that shows the number of teeth in the pinion and the ring gear, simple dividsion will give you the ratio. Sometimes the tag gives the ratio, like 3.55 or 3.73.
What kind of driving you do, also has imput into which gears you choose.
Shopping and sales can save a bunch, major suppliers are often the best bet. Customer service is also a criteria when choosing a gear supplier.
Gear changes aren´t often a do it yourself operation. Though they can be done youself, with some special tools and serious research.
Mike1 said:
Hi
Mike
Here's a chart. One for lift size, and one for gear/tire ratio. The gear/tire chart is subjective. You'll hear many arguments refuting the numbers, but it's about the concensus of what I've read and heard from others.
I run 33x 12.50 sized tires, and I have 4.56 gears installed. I think I could use 4.88's though. (if they made 4.88's for my axel... damn commies.):x
click here: http://www.collinsbrosjeep.com/tiregear.htm
