HELP! yj won't start
craig250
I'm new here but I need help 1991 yj 4.0 cranks fine but will not start it's getting fuel and I have spark occasionally it will start 3 time in 5 days and when it does it runs fine all ground are good new battery cable any help would be great thanks:???:
Is there any codes? You could turn the key off and on three times ending on and count the engine light blinks. The codes are two digit codes.
Second I take it cranks fine but doesn't start? Or describe exactly what happens.
Quick off the cuff. Crank position sensor.
