Harmonic Balancer squeal
PS89YJ
Have a squeal that is worse at start up. The all pulleys are okay and the serpentine belt is new and tight. A screwdriver next to the balancer and my ear I can hear the squeal. My 98 Wrangler 4.2 has the sensor for the injection timing. My question is does the balancer and sensor come off in one piece or two? Is there anything else that would cause the squeal?
PS89YJ
Paul
The only thing that I can think of that is squealing would be a slipping belt on the pulley. Is the belt tensioner within specification?
Use the water spray method. With the engine running and noise happening.
Safely spray a stream of water on the belt . If the sound stops the belt is loose. If not then pick a pulley. Cautiously Spray the center of the pulley. Do it from a distance do you do not get hurt by the moving parts.
When the noise disappears you found the pulley.
On TJ spp02 or 03 to 06 have screaming monkeys when the ODPA starts to fail.
JPNinPA
Using Jeepz.com app
