98Chero
I have a 1990 cherokee 4.0 liter six. Its hard to start but once it gets running it runs fine. I put a fuel pressure gauge on it today and when I turned the key and left it on the gauge read 30 psi and then bleeded down to zero. I started the engine and the fuel pressure stayed at 30 psi, but once i killed the motor it went back to zero. I was thinking that the fuel pressure should stay in the fuel rail for awhile. I was wondering if I have a bad check valve somewhere ? and if so where is it located ?. Im thinking that the fuel pressure is bleeding off somewhere.. maybe in the pressure regulator or the fuel pump area... any help would be greatly appreciated.
