GenRight Off Road
Given the wide variety of light bars on the market, we have made The GenRight Light Bar Mount a "universal mount" for any light bar with lengths up to 52". Some light bars may require drilling through the bottom of the bottom of the casing to mount bolts through, but gives you a way to "low-profile" mount using more than just the side two bolts to secure the light bar to the mount. You can seal the drill holes with silicone to maintain the "waterproof" feature of the light bar.
_______________________________
GenRight JK Light bar Mount:
Other FEATURES Include:
Heavy Duty steel construction.
Easy to adjust once installed on the Jeep.
Black Powder Coated finish.
Easy to install, bolt-on.
Includes mounting hardware.
Accepts the VisionX, 52" LED Light Bar (XIL1000).
Sold as a pair.
NOTE: Can mount other light bars but would have to make some modifications to the light bar (drill holes in the bottom as pictured below if slide-on bolt mounts not available for your light bar).
_____________________________________
Here are photos of "Addiction" with a 50" Alien brand LED light bar using the GenRight Light Bar Mount. There a 4 holes drilled 4 in the bottom of the casing, bolts fed through the inside of the light bar, along with a spacer between the casing and horizontal light bar mounting plate. Lock Nuts are used to secure it to the horizontal light bar mounting plate
Sold as a pair.
