fuel injection 2.5 what is the differance
promachining
I am trying to find out what the differance is between a 1990 2.5 throttle body injection and a 1993 tpi injection 2.5.
I mechanically know the differance but what about the driving differance. I assume the tpi is better but I know someone selling a 1990 throttle body wrangler for a good price and wanted to know is there a power differance, does the throttle body run fine on steep inclines like the tpi does.
Are there any problems with the throttle body etc.?
I had a 1993 tpi so I am familiar with the power output of that motor.
Any info would be great.
TPI injection? u mean MPI injection? The MPI injection is better with fuel milage and supposed to have more power.
OOPS your right that is what I meant. Thanks that is what I thought I figured they changed for better economy and maybe some more power but I wasn't sure. :D
The MPFI introduced in '91 is more effecient and produces more HP than the earlier TBI design.
MPFI=Mulit-Port Fuel Injection
TBI=Throttle Body Injection
also with the multi port you have an injector for each cylinder, if you have an injector problem it runs rough but runs.. if you have TBI - you have 1 injector - if it goes your dead..
