front ends
UMAPINEJEEPER
how many out there run welded up spider gear on the front of your jeeps we used to do this 25 years ago and good luck in the snow but remember 25 years ago we didnt have the traction on the ground on the side hills we would unlock one hub[addsig]
1046077
That is forgin to me! Sounds to me like you found a way to what you wanted to do! Nessity is the mother of invention! [addsig]
1046087
I run a Lincoln Locker (welded diff) front and back. The front pass. side axle shaft is disconnected on command by a vacuum switch I installed in the cab, got the switch from a full-size Jeep Cherokee with Quadratrac 4wd.
1/2 hour install.
This thing climbs like a mountain goat with true 4wd all the time. Unlocking one front axle makes tight turns on the trail a lot easier.[addsig]
