front axel u joints
grimmace1
im plannin on replacing mwheel bearings on my 2000 cherokee and figure id replace u joints while at it. what do you need to do to get axel out?
Not much if you already replace the bearings...
If I remember correctly, you have the remove the wheel hub in order to replace the bearing, when it is out, all you have to do is pull the axleshaft out....
Saar
