S Shane Jones New member Feb 4, 2017 #1 Both drivers side headlight and tail light are out. I replaced fuse for tail light but no help. Any suggestions? Thanks
JPNinPA Well-known member Feb 4, 2017 #2 Check your grounds. The tail light should ground to he tub as a part of the light mount. The headlight ground should be up front behind the grill. Regards, JPNinPA Sent using TapTalk
P paradineai New member Feb 5, 2017 #3 If on a 1999 - 2004 the tail light has an issue with the circuit board (alot), but if both are out then it is most likely a bad wire or the "light out sensor module" has gone out. Sent from my SM-J320V using Jeepz.com mobile app
J Jeepergeo Active member Feb 10, 2017 #4 Try running a supplemental, known ground. Also, carefully probe the light socket for power. Carefully, and don't shot it by accident. And check the obvious...are the bulbs good? That tail could have been out awhile and you might not have noticed it.
J Jeepergeo Active member Feb 10, 2017 #5 Is there power on both sides of the fuse? Probe with a grounded test light.
