drivers side door panel
98 Jeep
I have a 98 JGC Limited. I fear the next time I get in and pull the door shut the whole panel will come off. Do I need a new door panel or just those white plastic screws that I tried but just didn't have enough room to work with. Or should I just take it to an auto body shop and get it done right.
sounds like you need new screw anchors ( the white plugs the screws go into) or washers on the heads of the screws so the heads dont pull through the door panel
