prariepunk
Active member
I recently had a rear u joint failure where my drive shaft slid off the yoke and got all banged up on the road. Afterwards it had some nasty drive line vibration (starting around 30 mph) so I installed the SYE kit that I bought thinking that would remedy the situation... well I'd kinda did. It now shakes around 55 mph bad enough to make my feet tingle line using a chainsaw & shakes down to around 35 mph. What could be causing this? It's definitely drive line but I replaced the rear bearings in the t case & got a new Tom Woods driveshaft. I'm thinking either bad t case mount bushing or bad pinion bearings (or both)
