Door locks
Appears to be a common issue.
First try disconnecting and reconnecting harness at the door like when you remove the door.
Summarized from other source:
latch actuator goes bad back ordered at the dealer
In the passenger footwell, there is a control module in that footwell.
If you pull the cover off where you unhook the passenger door connector, this module is just forward of that, it was the white connector about in the middle of the module.
There are several connectors look for one connector that looks like it isnt all the way inserted.
Regards,
JPNinPA
Sent using TapTalk
