Diamond Plate Rockers?
Deadman
Where can I find diamond plate rocker panels for a 97 Cherokee? Mine are starting to rust through and I'd like to beef them up a bit with diamond plate if possible.
RE: Coil spring conversion in YJ
That '97 is rusting out rather early for an XJ. I would without a doubt find out how they have gotten moisture in there and address that along with cutting out all the existing rust. Unibody vehicles and rust are a bad combination.
2005 TTC videos
If you put on diamond plate over it, it will rust more no matter what you do...except for cutting out that rust and welding in some new pieces.
